Go Back   Horizons Unlimited - The HUBB > 4 wheels > Overland Vehicles and Equipment for Sale / Wanted
Overland Vehicles and Equipment for Sale / Wanted Overland vehicle or equipment - winches, shocks tires etc.
INCLUDE COUNTRY in subject, and include currency in the post
Please DELETE your post when it is sold.
NOTE: DO YOUR OWN HOMEWORK about the merits of any vehicle and the LEGALITIES of changing ownership.
Photo by Marc Gibaud, Clouds on Tres Cerros and Mount Fitzroy, Argentinian Patagonia
The only impossible journey
is the one
you never begin
Destination ANYWHERE...
Adventure EVERYWHERE!
Reply
LinkBack Thread Tools Display Modes
  #1
Old 25 Oct 2019
Registered Users
HUBB regular
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK
This must be one of the best examples of an overland vehicle in Britain. The latest set-up has been proven to work over the last 10 years taking us across Siberia and then from Alaska to Terra del fuego.
This vehicle as I have been led to believe, has never been used in a British winter. The first owner mainly used it to tow a caravan around Spain during the winter, I bought it in 2006 with a FSH and 110k miles recorded and we have only used it for overland travel.
Mechanically this is sound and good to go, after fitting new tires, to cross another continent. Since the last trip I have serviced everything and I mean everything.
Front Axle: Birfield, Wheel bearings, knuckle bearings and all seals / gaskets changed if required. Diff re-built with new bearings.
Rear Axle: Wheel bearings and oil/dust seals replaced. Diff re-built with new bearings.
Diff ring gear has been changed to 410 ratio, speedo shows correct reading with 33” tires.
Front & Rear propshaft rebuilt with new spider joint.
The above has been done, before each major trip.
This time I have had a new sliding joint fitted to the front and rear propshaft.
I went through many spider joints over the year some replaced on the road( they do not like water) another reason of the wearing spider joints is a worn sliding joint!
The Gearbox has been stripped and re-built with new bearings. It turned out that all the original bearings and thrust washers were in spec!
Engine: Fuel pump striped and rebuilt with new parts as required and setup to work with a fitted intercooler and the injectors have been refurbished. Cam belt and tensioner replaced around 10k miles ago.
Engine starts first every time weather hot or cold at sea level or at 5000m. Does not burn oil, oil stays relativity clear for the first 500miles. Oil has been changed every 5000 miles since I have had it.
A low radiator fluid sensor has been fitted to the header tank to give an early warning before the level gets close to the head.
An intercooler has been fitted mainly to improve MPG, leaving boost around 10psi.
Brakes front and rear have been refurbished and the exposed brake pipes have been change. The front / rear balance valve has been changed and the balance adjusted for this setup.
Additional Equipment fitted
HD front winch bumper with a winch fitted, using a synthetic rope. Controlled either by cable or a remote. Day LED day lights fitted flush in the bumper.
ARB twin wheel rear carrier.
Longrange 170ltr stainless steel aux. fuel tank, transfers fuel to the main tank from a switch within the cabin. Uses a Toyota valve to switch between tanks when filling. The bottom of the tank has a 6mm aluminium custom made bash plate for protection.
There is also a custom made bash plate covering the gearbox and transfer box, with another bash plate to help protect the steering tie rods.
Pop-up roof made out of Aluminium plate, with light weight composite board. The sleeping floor is also made out of light weight composite board adding roughly 30kg over the standard roof.
double solar panels supply up to 200w to the two auxiliary deep cycle batteries. This more than enough to run the Engel fridge/freezer and other electrical items whilst camping. These batteries are charged through a Sterling 60amp battery to battery charger, which tricks the alternator to charge the batteries at a fast rate.
There is a 70ltr cold water tank and a 25ltr heat exchanger that has been connected to the engine cooling system taking the heat from the radiator, giving hot and cold water supply. The water is filtered through 2 stage filters and a UV filter which can be turned on or off.
There is a shower outlet fitted at the back.
The inside has been fitted out with fitted units made out of light weight flight case material, giving ample storage space. A combined kitchen sink and a 2 ring burner with a glass cover. There is also a secret compartment for those items you need to keep hidden.
A 42/45 ltr Engel.
Erbacher diesel heater has been fitted and has been modified to work up to 3000mts though probably work up to 4000mts.
A 300w 12v to 240v inverter is also fitted.
An external aerial for the Garmin GPS and may work for other systems.
An external WiFi booster aerial is fitted
A custom made aluminium box designed to fit on the front section of the roof for those bulky yet relativity light items, like winter clothing, walking boots etc.
A pair of Maxtrac ladders(very useful).
Front seats fitted with new Escape Gear seat covers.
Spares
Starter motor
Alternator
Repair kit for Starter motor
Water pump( the original)
various bearings for wheels, and swivel joints.
various dust seals/oil seals
Cam pulley locking tool.
Hub nut box spanner.
Offers around £20000
For more information please PM me.
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-dsc06385.jpg
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-dsc06394.jpg
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-dsc06397.jpg
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-dsc06388.jpg
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-p1250183.jpg
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-dsc06389.jpg
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-dsc06391.jpg
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-dsc06392.jpg
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-p1250019.jpg
Toyota Landcruiser 80 (1996 24v 4.2 TD) for overland travel located in UK-p1020116.jpg
  #2
Old 21 Feb 2020
Registered Users
HUBB regular
This well equipped vehicle is still for sale and open to any reasonable offers. Please PM me for further details.
  #3
Old 24 Feb 2020
Registered Users
HUBB regular
Nice! If anyone asks, I'll point them your way.
__________________
Enzo - 78 Series Landcruiser - 1HZ
Amazon - FaceBook
  #4
Old 17 May 2025
vlro's Avatar
Gold Member
New on the HUBB
Hi , is the LC still for sale - i think i did see it somwhere ?Thanks Rob
Reply
Currently Active Users Viewing This Thread: 1 (0 Registered Users and/or Members and 1 guests)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
"80 series RHD British 1996 24v Landcruiser for Sale" claters Overland Vehicles and Equipment for Sale / Wanted 6 9 Jan 2016 16:53
Toyota Landcruiser 100-series UK reg Currently in SA gary.rosewarne Overland Vehicles and Equipment for Sale / Wanted 0 30 Oct 2012 18:43
1995 Toyota Landcruiser 80 series, VX 4.2 diesel, manual, 24v, diff locks in UK barbaraH Overland Vehicles and Equipment for Sale / Wanted 20 8 Jun 2012 00:01
Toyota Landcruiser (80 Series) 4.2cc Turbo Diesel (UK Reg) FOR SALE: CAPE TOWN JRUK Overland Vehicles and Equipment for Sale / Wanted 0 28 May 2012 09:29
Be sure to join us for this huge milestone!
2025 Confirmed Events:
Virginia: April 24-27
Queensland is back! May 2-5
Germany Summer: May 29-June 1
Ecuador June 13-15
Bulgaria Mini: June 27-29
CanWest: July 10-13
Switzerland: Aug 14-17
Romania: Aug 22-24
Austria: Sept. 11-14
California: September 18-21
France: September 19-21
New York: October 9-12 NEW!
Germany Autumn: Oct 30-Nov 2
2026 Confirmed Dates:
(get your holidays booked!)
Virginia: April 23-26
Queensland: May 1-4
CanWest: July 9-12
See all event details
World's most listened to Adventure Motorbike Show!
Check the RAW segments; Grant, your HU host is on every month!
Episodes below to listen to while you, err, pretend to do something or other...
Adventurous Bikers – We've got all your Hygiene & Protection needs SORTED! Powdered Hair & Body Wash, Moisturising Cream Insect Repellent, and Moisturising Cream Sunscreen SPF50. ESSENTIAL | CONVENIENT | FUNCTIONAL.
2020 Edition of Chris Scott's Adventure Motorcycling Handbook.
"Ultimate global guide for red-blooded bikers planning overseas exploration. Covers choice & preparation of best bike, shipping overseas, baggage design, riding techniques, travel health, visas, documentation, safety and useful addresses." Recommended. (Grant)
Ripcord Rescue Travel Insurance.
Led by special operations veterans, Stanford Medicine affiliated physicians, paramedics and other travel experts, Ripcord is perfect for adventure seekers, climbers, skiers, sports enthusiasts, hunters, international travelers, humanitarian efforts, expeditions and more.
Ripcord Rescue Travel Insurance™ combines into a single integrated program the best evacuation and rescue with the premier travel insurance coverages designed for adventurers and travel is covered on motorcycles of all sizes.
(ONLY US RESIDENTS and currently has a limit of 60 days.)
Ripcord Evacuation Insurance is available for ALL nationalities.
What others say about HU...
"This site is the BIBLE for international bike travelers." Greg, Australia
"Thank you! The web site, The travels, The insight, The inspiration, Everything, just thanks." Colin, UK
"My friend and I are planning a trip from Singapore to England... We found (the HU) site invaluable as an aid to planning and have based a lot of our purchases (bikes, riding gear, etc.) on what we have learned from this site." Phil, Australia
"I for one always had an adventurous spirit, but you and Susan lit the fire for my trip and I'll be forever grateful for what you two do to inspire others to just do it." Brent, USA
"Your website is a mecca of valuable information and the (video) series is informative, entertaining, and inspiring!" Jennifer, Canada
"Your worldwide organisation and events are the Go To places to for all serious touring and aspiring touring bikers." Trevor, South Africa
"This is the answer to all my questions." Haydn, Australia
"Keep going the excellent work you are doing for Horizons Unlimited - I love it!" Thomas, Germany
Lots more comments here!
Five books by Graham Field!
Every book a diary
Every chapter a day
Every day a journey
Refreshingly honest and compelling tales: the hights and lows of a life on the road. Solo, unsupported, budget journeys of discovery.
Authentic, engaging and evocative travel memoirs, overland, around the world and through life.
All 8 books available from the author or as eBooks and audio books
Back Road Map Books and Backroad GPS Maps for all of Canada - a must have!
New to Horizons Unlimited?
New to motorcycle travelling? New to the HU site? Confused? Too many options? It's really very simple - just 4 easy steps!
Horizons Unlimited was founded in 1997 by Grant and Susan Johnson following their journey around the world on a BMW R80G/S.
Susan and Grant Johnson Read more about Grant & Susan's story
Membership - help keep us going!
Horizons Unlimited is not a big multi-national company, just two people who love motorcycle travel and have grown what started as a hobby in 1997 into a full time job (usually 8-10 hours per day and 7 days a week) and a labour of love. To keep it going and a roof over our heads, we run events all over the world with the help of volunteers; we sell inspirational and informative DVDs; we have a few selected advertisers; and we make a small amount from memberships.
You don't have to be a Member to come to an HU meeting, access the website, or ask questions on the HUBB. What you get for your membership contribution is our sincere gratitude, good karma and knowing that you're helping to keep the motorcycle travel dream alive. Contributing Members and Gold Members do get additional features on the HUBB. Here's a list of all the Member benefits on the HUBB.
