Go Back   Horizons Unlimited - The HUBB > Technical, Bike forums > BMW Tech
BMW Tech BMW Tech Forum - For Questions specific and of interest to BMW riders only.
Photo by Ulrike Hahnel, Rock Formations on the Lagune Route, Bolivia
I haven't been everywhere...
but it's on my list!
Like Tree5Likes
Reply
LinkBack Thread Tools Display Modes
  #16
Old 9 Jan 2013
Registered Users
Veteran HUBBer
Quote:
Originally Posted by Macca View Post
Just doing the sums and there's about a AUD $5000 (US $2500) difference between the R80GS and R100GS, so if I was to purchase the R80GS and put the spare cash (who's got spare cash these days?) into 'jazzing' up the bike mechanically (Munich Motorcycles - and this is not intended to be a commercial plug) am I on the right tangent, or go for the R100GS.
The bike is for two-up travel, and I note that Grant does recommend either the 80 or 100 for two-up (I actually prefer the Tiger but that's another storey).
Also guys & gals what would be the preferred options to the 'winner'?
Macca & Lynda
Without adventure life is in full decay.
It depends more on your requirement than on the differences between these two beemer options.
R80 runns ok/well with a road-weight(?) of 350-400kg. 450kg is ok as well, but hitting 500kg... it does get sluggish...
It is a smooth running, sweat and soft engine, especially in the version that you are asking about (8.2:1 50hp).
You will however find that raising the compression by swapping pistons to the 9.2:1 55hp pistons will be a -good- investment. The engine becomes a little "raw" though, and a triffle "nervous".
R100 - far more power. Better milage. Runns cooler. Raw. Brutal. Not to my liking (though I do use them).
The light-weight tune-up kit from Germany is however a very neat tuning; the engine will not be as brutal and raw. It will be more rev-willing.
In either case, both models benefits from oil-cooler...
As for cutting costs...
50hp... vs 67(ish)hp
50(ish)Nm... vs 75(ish)Nm...
...that -is- a huge difference...
You will/may spend a bit on fixing the power-less 800cc engine I guess...
55hp and 56Nm is ok though... and that will set you back about 3-400USD (if prices have not risen since I checked), if you can swap the pistons yourself i.e.
As for tuning options:
www.motoren-israel.de
The 800 cc engine benefits hugely from T-shaped high-flow valves, e.g. Buggpack 44mm. That would require new seats though, so less you plane to change seats 42mm high-flow-valves would be your option. Bugpack valves costs about 50-60USD each, needs to be shortened and new collet groves swiveld and lasp-caps added. The power increase is modest, but pushing the power just over the sluggish limit; the engine will get that little extra that makes it ok to drive.
Dual-plugging is a tuning that I recommed, but it is costly. (I wrote about it in 2008; "ITU gone bust" I think I called the string).
__________________
Drive Safely,
Albert
  #17
Old 27 Apr 2013
Registered Users
New on the HUBB
2013 KTM 990 or F800GS
Hello,
This will be my first ADV bike so I am looking for any recommendations or advice. I have been riding sports bike for the past 20 years and its time to transition to different bike with more capabilities. I have some experience with dirt bikes but not a expert. I am thinking between 2013 KTM 990 ADV Baja Limited Edition or F800GS. Looking forward to your feed back.
KC
  #18
Old 28 Apr 2013
Registered Users
Veteran HUBBer
Quote:
Originally Posted by kc275a View Post
Hello,
KC
You might be better off posting a new question in the which bike section rather than on a thread about completely different bikes to the ones you are interested in.
  #19
Old 29 Dec 2021
*Touring Ted*'s Avatar
Contributing Member
Veteran HUBBer
I love googling something and finding a post from the HUBB.
FROM TWENTY YEARS AGO.
And it's just as relevant today as it was then.
Suck that Facebook.
__________________
Did some trips.
Rode some bikes.
Fix them for a living.
Can't say anymore.
  #20
Old 21 Sep 2023
Registered Users
Veteran HUBBer
R80 GS,G/S versus R100 GS
one further piece of information that may be relevant to some in regard to the above is that the electrical output is less (around 280 I think for the above bikes) than many later model motorcycles such as the 1000cc Africa Twin. If you need to run additional lights and say various pieces of heated clothing plus GPS etc, then you may need to consider this aspect, although some clever people may figure a way around this issue.
  #21
Old 21 Sep 2023
Grant Johnson's Avatar
HU Founder
Veteran HUBBer
There are indeed upgrade kits for the anemic airhead electrics. Stock is 240 watts, and struggles unless you keep the revs up. EARLY airhead R75 owners in the US complained of major electrical issues, dead batteries etc. Germany didn't understand why, until they discovered the average North American rider rode around under 4000 rpm, not wanting to "stress" the engine, or perhaps used to slow revving Harleys, and old English bikes. The airheads didn't START to charge until 4000! Changes were made, but barely adequate. If you knew to rev it they were fine.
An excellent kit available: https://www.bmwmoa.org/blogpost/1239...e-for-Airheads
I have an early version, I think 450 watts, in my R80G/S and it works fine, nice simple bolt in upgrade and extremely reliable. I can run two electric vests, electric gloves and a 100 watt headlight without issue.
Another is: https://www.euromotoelectrics.com/product-p/edl4.htm
__________________
Grant Johnson
Seek, and ye shall find.
Inspiring, Informing and Connecting travellers since 1997!
www.HorizonsUnlimited.com
  #22
Old 21 Sep 2023
HU Founder
Veteran HUBBer
We rode around the world two up with a stock (plus dual plugging and oil cooler) R80G/S, and the power was fine. Not great on the Autobahn, but generally adequate everywhere and more than enough most of the time.
Returning home, and then in the UK, I upgraded to 1000cc with a complete R100 top end with 40 mm carbs. FAR better power, MORE vibration, WORSE fuel mileage. For NA and Europe, a better choice. But the R80 engine is VERY nice, sweet, low vibes, pleasant to ride. The R100 is as noted above, more RAW - which you might like . No surprise to me, as I'd had a couple of R100S's before.
Given a choice, I'd go for the R100GS paralever version, despite the flaws. Overall better. Tubeless, longer wheelbase, much bigger battery, stronger forks (I put R100GS forks on my R80G/S), better front brake.
__________________
Grant Johnson
  #23
Old 21 Jan 2024
Registered Users
HUBB regular
I just wanna thank everyone for the information in this thread really useful I'd been weighing up r80's vs r100gs's to sit alongside my 1150 so a big help
Reply
Currently Active Users Viewing This Thread: 1 (0 Registered Users and/or Members and 1 guests)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
  • California: April 18-21
  • Virginia: April 25-28
  • Germany Summer: May 9-12
  • Québec: May 17-19
  • Bulgaria Mini: July 5-7
  • CanWest: July 11-14
  • Switzerland: August 15-18
  • Ecuador: August 23-25
  • Romania: August 30-Sept 1
  • Austria: September 12-15
  • France: September 20-22
  • Germany Autumn: Oct 31-Nov 3
2025 Confirmed Events:
  • Virginia: April 24-27 2025
  • Queensland is back! May 2-4 2025
  • Germany Summer: May 29-June 1 2025
  • CanWest: July 10-13 2025
  • Switzerland: Date TBC
  • Ecuador: Date TBC
  • Romania: Date TBC
  • Austria: Sept. 11-15
  • California: September 18-21
  • France: September 19-21 2025
  • Germany Autumn: Oct 30-Nov 2 2025
See all event details
World's most listened to Adventure Motorbike Show!
Check the RAW segments; Grant, your HU host is on every month!
Episodes below to listen to while you, err, pretend to do something or other...
Adventurous Bikers – We've got all your Hygiene & Protection needs SORTED! Powdered Hair & Body Wash, Moisturising Cream Insect Repellent, and Moisturising Cream Sunscreen SPF50. ESSENTIAL | CONVENIENT | FUNCTIONAL.
2020 Edition of Chris Scott's Adventure Motorcycling Handbook.
"Ultimate global guide for red-blooded bikers planning overseas exploration. Covers choice & preparation of best bike, shipping overseas, baggage design, riding techniques, travel health, visas, documentation, safety and useful addresses." Recommended. (Grant)
Ripcord Rescue Travel Insurance.
Ripcord Rescue Travel Insurance™ combines into a single integrated program the best evacuation and rescue with the premier travel insurance coverages designed for adventurers.
Led by special operations veterans, Stanford Medicine affiliated physicians, paramedics and other travel experts, Ripcord is perfect for adventure seekers, climbers, skiers, sports enthusiasts, hunters, international travelers, humanitarian efforts, expeditions and more.
Ripcord travel protection is now available for ALL nationalities, and travel is covered on motorcycles of all sizes!
What others say about HU...
"This site is the BIBLE for international bike travelers." Greg, Australia
"Thank you! The web site, The travels, The insight, The inspiration, Everything, just thanks." Colin, UK
"My friend and I are planning a trip from Singapore to England... We found (the HU) site invaluable as an aid to planning and have based a lot of our purchases (bikes, riding gear, etc.) on what we have learned from this site." Phil, Australia
"I for one always had an adventurous spirit, but you and Susan lit the fire for my trip and I'll be forever grateful for what you two do to inspire others to just do it." Brent, USA
"Your website is a mecca of valuable information and the (video) series is informative, entertaining, and inspiring!" Jennifer, Canada
"Your worldwide organisation and events are the Go To places to for all serious touring and aspiring touring bikers." Trevor, South Africa
"This is the answer to all my questions." Haydn, Australia
"Keep going the excellent work you are doing for Horizons Unlimited - I love it!" Thomas, Germany
Lots more comments here!
Five books by Graham Field!
Diaries of a compulsive traveller
by Graham Field
Book, eBook, Audiobook
"A compelling, honest, inspiring and entertaining writing style with a built-in feel-good factor" Get them NOW from the authors' website and Amazon.com, Amazon.ca, Amazon.co.uk.
Back Road Map Books and Backroad GPS Maps for all of Canada - a must have!
New to Horizons Unlimited?
New to motorcycle travelling? New to the HU site? Confused? Too many options? It's really very simple - just 4 easy steps!
Horizons Unlimited was founded in 1997 by Grant and Susan Johnson following their journey around the world on a BMW R80G/S.
Susan and Grant Johnson Read more about Grant & Susan's story
Membership - help keep us going!
Horizons Unlimited is not a big multi-national company, just two people who love motorcycle travel and have grown what started as a hobby in 1997 into a full time job (usually 8-10 hours per day and 7 days a week) and a labour of love. To keep it going and a roof over our heads, we run events all over the world with the help of volunteers; we sell inspirational and informative DVDs; we have a few selected advertisers; and we make a small amount from memberships.
You don't have to be a Member to come to an HU meeting, access the website, or ask questions on the HUBB. What you get for your membership contribution is our sincere gratitude, good karma and knowing that you're helping to keep the motorcycle travel dream alive. Contributing Members and Gold Members do get additional features on the HUBB. Here's a list of all the Member benefits on the HUBB.
